August 2, 2018, 23:58 |
FSI with fluent and mechanical
Pravil C Prakash
Rep Power: 8 |
Hi
I am trying to do FSI with fluent and mechanical for a rotating propeller. In fluent the settings are transient, pressure based, k epsilon model with mesh motion. I used same geometry with both fluid volume and actual solid blade. After running transient analysis in fluent the pressure is imported to mechanical, but the source points of blade in fluid volume were in angular offset to actual solid blade. Only a part of pressure is correctly transferred to the blade area. How to solve this problem ? Last edited by pravilcp; August 7, 2018 at 00:48. |
August 7, 2018, 00:50 |
Pravil C Prakash
Rep Power: 8 |
Can anyone please provide me a solution for this...? |
January 21, 2019, 15:21 |
Rep Power: 10 |
Are you still working on this issue? I might be able to offer some insight if I knew more about it.
fluent, fsi, mechanical coupling |
problem with creating artery thickness for FSI methode using fluent and mechanical | raminostadi | FLUENT | 1 | June 6, 2020 06:17 |
two way FSI error fluent and mechanical | r_abdollahi70 | FLUENT | 0 | January 6, 2018 04:04 |
FSI Fluent + Mechanical | destroy | ANSYS | 0 | October 24, 2017 14:28 |
2way FSI Fluent Mechanical SETUP Problems | MainzerKaiser | ANSYS | 7 | May 20, 2016 12:22 |
Mechanical fails, MAPDL doesn't..FSI | KeganLeckness | Structural Mechanics | 0 | August 17, 2015 17:34 |
