Extract results for a BC via .prof (profile) to use it for the new .cas file
Like Tree3Likes
  • 1 Post By LuckyTran
  • 1 Post By obscureed
Old   June 26, 2018, 07:04
Default Extract results for a BC via .prof (profile) to use it for the new .cas file
Onur Özcan
oozcan is on a distinguished road
Hello guys,
I got a .case file which is previously has been created and see that a boundary condition,velocity inlet, has .prof (profile data) in all directions. I got .prof file in same folder and looked via .notepad. But i am looking for how that .prof had been created. Possibly it has been get a previous .dat file. How does it extract as .prof file for any boundary condition (for previous .dat file) ?
Because it is not possible to write it manually in text file.
Really in advance appreciated!
oozcan is offline   Reply With Quote
Old   June 26, 2018, 09:30
Lucky
Either it was manually created or it is the solution data written by Fluent into a .prof format. Fluent simply writes the data of chosen variables at faces/nodes (I can't remember which).
oozcan likes this.
Old   June 26, 2018, 13:00
Onur Özcan
Thank you,
I have resolved the problem. Similarly, can we also extract temperature/pressure/velocity of interest for the any "CELL ZONE" ?
Old   June 27, 2018, 03:46
obscureed is on a distinguished road
Hi Oozcan,
Please can you tell us how you resolved the issue, for anyone who finds this thread in the future?
My suggestion was going to be to try writing out a settings file. This can only be done through typing a TUI command into the command window: /file/write-settings. I think this creates a profile file for any loaded profiles.
For writing and reading cell-zone data, look at the top menu item File...Interpolate. (Bear in mind, though, that reading in an interpolation file can be hit-and-miss when the meshes are not identical.)
Good luck!
Ed
oozcan likes this.
obscureed is offline   Reply With Quote
Old   June 27, 2018, 12:29
Lucky
I don't see where there is any problem...?
Profiles can be written for boundaries or cell zones.
There are several ways to extract data from any cell zone, not necessarily involving a .prof file. What is your asking about? What do you need help with?
oozcan likes this.
Old   June 27, 2018, 13:29
Onur Özcan
I figured out how I set .prof file for the new one .case file. But I really have not seen the cell zone by using .prof file. If it not possible, how can I extract cell zone of interest to new .case file? what is the way I get?
Best Regards,
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
