May 21, 2018, 04:49 |
Read Force Report by UDF
DS
Rep Power: 10 |
Good morning,
I'm writing an UDF function and I need to read the values setted in Report Definition-->Force Report. I read some other forums, but I didn't find any usefull answer. In particular I know that with the Report Definition I could save .txt files with the forces and maybe read them with the UDF. But I prefer to read the values by UDF directly maybe saving them in a RPvariable if possible. Could some one help me to explay how to access to that variables? Thank you very much Best regard Denis |
June 1, 2018, 10:11 |
Force and moment calculation udf
DS
Rep Power: 10 |
Good morning,
I understood that is impossible to import in the UDF the forces and moments. I would ask if someone has already written a code to evaluated forces and moments in parallel code and 3D domain including pressure and viscosity contributions. Thank you really much Best Regard Denis |
report definition udf |
Different force result: DEFINE_Source UDF & without UDF | A.Rah | FLUENT | 1 | November 11, 2017 08:22 |
UDF in Fluent | Andrew | Fluent UDF and Scheme Programming | 5 | March 7, 2016 04:38 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
Read profile file from UDF | DonQuijote | Fluent UDF and Scheme Programming | 0 | February 18, 2013 12:56 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 10:46 |
