simulation supersonic external flow arround the missile diverge!! |
April 13, 2018, 02:34 |
ramin
Rep Power: 10 |
hello everyone .I'm working on shock wave behind the rocket (missile) for one month . I simulate supersonic flow arrond the rocket. my conditions are:
mesh : I try for improving mesh quality but inflation layer error stair mesh. pressure far field: Mach=2.6 , static pressure=1171 pa , Temperature= 227k rocket surface: wall , operation pressure=zero pascal ideal gas for air , sst-kw model. solution initialization: standard from far field. solution method: both density based and pressure based. when I run density based; this errors ocure : absolute pressure and temperature limite to 1. I change limits and change courant number, I change relaxation factors but solution diverge again. when I run pressure based; continuty residuals increase to 1000 and solution diverge, I change relaxation factors and solution diverge again. I'm not sure but I think the problem is my mesh quality because I can't inflation layers around the rocket. I really try for improving mesh quality but only I can change mesh sizing. I'm really tired. please help me. if one of you can solve my problem, I will send you my Ansys file to your email. please help me. |
April 13, 2018, 06:18 |
change the operating pressure to 101325 Pa , are you working on 2D or 3D model ? share pictures mesh cross sections.
April 14, 2018, 13:13 |
ramin
Rep Power: 10 |
I'm working on 3d model. Ithink, I should set operation pressure to zero for supersonic flow. I share my mesh.
I solve my problem by changing URF. but continuty residual reach 0.8 slowly. after that it remain constant (I share picture) . I want to export pressure result to mechanical for fsi, then continuty converging is very important for me. thank you. geometry.JPG Capture 1 .JPG Capture 3.JPG Capture2.jpg Capture5.JPG |
How to manage the pressure term in fixed mass flow rate based channel flow simulation | sjwon1991 | Main CFD Forum | 5 | July 10, 2017 08:21 |
Freestream Setup in an External Flow Simulation | phathomie27 | STAR-CCM+ | 1 | January 6, 2017 08:00 |
Supersonic Nozzle Exhaust Simulation | mikeh | FLUENT | 0 | May 1, 2014 22:28 |
How to set a 'farfield' boundary for supersonic external flow in OpenFOAM? | hg2lf | OpenFOAM Pre-Processing | 0 | April 5, 2014 13:54 |
Inviscid Supersonic Flow Simulation | Alan | OpenFOAM Running, Solving & CFD | 2 | July 27, 2009 04:36 |
