October 5, 2017, 02:57 |
Wet Steam Model
Rep Power: 9 |
Hello all,
i am using the wet steam model in Fluent to simulate the condensation process which take place during the expansion of steam in a LP-turbine. In this model variable such as the generation rate J, the critical droplet radius r* or the super saturation S are calculated from the property. I know i can set my own property functions and data using a user-defined wet steam property function (UDWSPF). But is there any possibility to access to the calculated variable (J, r*,S, ...) within my UDF? My purpose is to use the r* value to define the surface tension for example. Can anyone help me? Thank you in advance for your help. |
surface tension, udwspf, wet steam |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Wet Steam Model | Martin007 | Main CFD Forum | 0 | December 19, 2016 16:02 |
Condensing Steam Analysis - What Model Should I Use?? | victorz | FLUENT | 5 | November 28, 2016 23:12 |
DPM Simulation with Wet Steam | AbbasRahimi | Fluent Multiphase | 1 | June 16, 2015 09:19 |
superheated wet steam (avoid condensation in a nozzle) | Ralf Schmidt | FLUENT | 0 | August 11, 2009 12:55 |
