Ansys Fluent
Old   April 4, 2017, 14:21
Lightbulb Ansys Fluent
Bett is on a distinguished road
Hi, i am doing my non-premixed engine combustion simulation with ANSYS FLUENT. I have output mass-average absolute pressure, temperature and volume for validation. Although pressure can match the validation but for heat release rate and temperature were so smaller compare to experimental data. Izzit the report type problem and usually what report type will be use for pressure, temperature?, NOx and soot? N with the equation of HRR, i put the absolute pressure in each time step in P, volume in V and change of pressure in each time step and change in volume in each time step and gamma i using 1.4 . I wonder i put the wrong term inside? I am using RNG K-epsilon, there got swirl dominated flow and inside can chg the swirl factor. is the swirl factor same meaning with swirl ratio?
Bett is offline   Reply With Quote
ansys fluent 17.2
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro cheezum Hardware 0 February 28, 2017 11:23
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
