March 9, 2017, 01:15 |
Solver setting when using hexahedral mesh
raunak jung pandey
Rep Power: 10 |
I am using Fluent to perform my simulations. I have a simple geometry and using K-e model.
Mesh used is hexahedral mesh. I have checked the mesh quality. Velocity inlet and pressure outlet condition is used. Pressure velocity coupling - simple gradient - least square based 1st order upwind for pressure momentum Reynolds number 30000 and mach no is 0.9 My solution doesn't converges with the default setting. Is it is because I am using hexahedral mesh ? Does it need different numerical settings than tetra mesh ? Last edited by raunakjung; March 9, 2017 at 02:34. |
March 9, 2017, 02:03 |
Lucky
Rep Power: 66 |
Not really.
Try a different initial guess. |
March 9, 2017, 02:34 |
raunak jung pandey
Rep Power: 10 |
Thank you for replying. Does convergence depend upon intial guess ?
solver settings |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
[Other] Pointwise Mesh into Fluent - Error: "Divergence detected in AMG solver: ads-0." | kyles.sverige | ANSYS Meshing & Geometry | 3 | January 27, 2015 13:28 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
