How can I calculate Cp for a VAWT on ASYS FLUENT ?
Old   February 19, 2017, 09:37
Default How can I calculate Cp for a VAWT on ASYS FLUENT ?
Aymane EDDAHMANI
aymaneed is on a distinguished road
For my bachelor's thesis, I am working on a simulation for different designs of a Savonius VAWT.
I am using Ansys Fluent.
Since the rotor will be*rotating, I am using a moving reference frame for the sphere enclosing the rotor, and a stationary box enclosing the sphere.
My initial understanding was that I will specify the wind velocity, and that the rotational speed will be an output of the simulation in addition to the torque, pressure and other variables.
However the necessary moving frame of reference requires as input the rotational velocity.
I calculated a rotational velocity that will result in a tip speed ratio of 1 for the the wind speed I am using, and used these values to run the simulation.
My question is why do we have to specify both the wind speed and the rotational speed ? Shouldn't the rotational speed (and consequently the rip speed ratio) be resulting from the specified*wind velocity ?
How descriptive is the simulation in this case ?
Thank you in advance.
aymaneed is offline   Reply With Quote
fluent, savonius rotor
How to calculate the torque in transient Ansys Fluent dynamic FLUENT 3 January 27, 2016 06:10
How to calculate heat transfer coefficient in FLUENT? ReVl27 FLUENT 3 November 12, 2015 01:44
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
How Fluent calculate Y+ for Multi fluids model mohibanwar Fluent Multiphase 1 August 29, 2015 21:40
Sliding mesh of 2D VAWT in fluent hasan47 FLUENT 2 January 10, 2014 03:55
