Judging convergence
Like Tree1Likes
  • 1 Post By amin.z
Old   July 14, 2016, 01:26
Exclamation Judging convergence
Zeinab
Zeinaby is on a distinguished road
Hello everyone,
I have modeled flow past a cylinder with Fluent. I need some advice in terms of judging convergence.
The flow is turbulent using the K-w-sst turbulence model. I also changed the "under-relaxation factor" as instructed in user guide:
"If unstable or divergent behavior is observed, however, you need to reduce the under-relaxation factors for pressure, momentum, k, and epsilon from their default values to about 0.2, 0.5, 0.5, and 0.5"
I don't understand what this convergence history means. (Please see the attached photo). The solution is converged but I'm not sure what the fluctuations imply.
I appreciate any comments.
Cheers
Zeinab
Zeinaby is offline   Reply With Quote
Old   July 14, 2016, 02:26
amin.z's Avatar
Amin
amin.z is on a distinguished road
It seems alright. You're solving a transient fluid flow, in this kind of problems the solver uses the result of the converged iteration in previous time step as a first guess ( what we call initialize in fluent) for the next one. so suddenly the the residuals soar then drop and converge .
Zeinaby likes this.
amin.z is offline   Reply With Quote
convergence, flow past a cylinder, fluent
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
In the case of convergence aja1345 FLUENT 1 July 31, 2015 04:58
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 13:18
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
