calculate mass flow rate from velocity contour
Old   June 10, 2016, 11:37
Default calculate mass flow rate from velocity contour
hosein
hosein72 is on a distinguished road
Hi.
A. I run a simulation on fluent. I have a problem. I find mass flow rate on inlet from 2 ways:
1. from Report>fluxes>mass flow rate
2. from axial velocity contour, with velocity and area (density is constant), I can compute mass flow rate nearly.
from 2 way, mass flow rates are very different. Are contours are correct or report?
I have another questions:
B. If a simulation run for a long time, how can I understand that it will be converge or never converge?!
C. I want to fix mass flow rate in input and output. what kind of boundary conditions is appropriate if the fluid is ideal gas and compressible.
thank you
hosein72 is offline   Reply With Quote
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
calculating mass flow rate from exported velocity values Sasha FLUENT 0 April 6, 2009 17:07
Mass flow rate Neser CFX 4 February 14, 2004 01:27
