Energy balance in laminar simulation
Old   October 2, 2014, 11:52
Default Energy balance in laminar simulation
dpitz is on a distinguished road
I'm running a buoyant rotating flow in Fluent using an unsteady 2D axisymmetric model. My geometry is a cylinder with adiabatic side walls, heated outer cylindrical wall and cooled inner cylindrical wall. Even though the residual of the energy equation is small (<10^-8), the energy entering the cavity does not equal the energy leaving it (the difference between the heat transfers is sometimes 25% of the total energy).
To investigate the cause of the problem I tried to run a simple conduction problem, with no rotation and no gravity. The temperature profile in the radial direction is correct, but still the energy balance is not zero. For this simple case the heat transfer rate at the outer wall is 5.35 W and -4.93 W at the inner wall, using a 100x100 mesh refined near the walls. For such a simple case I would expect the energy balance to be very close to zero, which is not the case.
Does anyone know what is wrong?
Thank you.
dpitz is offline   Reply With Quote
Natural convection, problems with total energy balance MdoNascimento STAR-CCM+ 0 March 13, 2014 13:15
Laminar simulation with Simple Algorithms and Coupled Algorithms. lienien FLUENT 4 April 30, 2013 12:15
energy balance zdz198728 Main CFD Forum 1 November 19, 2009 01:07
Laminar Zone in Turbulent Simulation Demetrios FLUENT 6 June 6, 2007 11:36
Energy balance Julie Polyakh Siemens 9 July 7, 2004 05:00
