Fluent analysis of heat source in a room
Like Tree1Likes
  • 1 Post By vishnu_240
Old   September 11, 2014, 11:09
Default Fluent analysis of heat source in a room
Vishnu C
vishnu_240 is on a distinguished road
Hi every one, I need some glimpse for simulating a heat source in a room in fluent, please do provide me with your valuable suggestions and any previous works. Thank you.
Andiee likes this.
vishnu_240 is offline   Reply With Quote
Old   September 12, 2014, 05:02
Vishnu C
The heat is due to the fire from circular gas burner, fueled with methane. I need to know how to model this fire source in Fluent, solution procedure, boundary conditions. please do provide me with your valuable suggestions and any previous works. Thank you.
Old   September 12, 2014, 08:26
Sangwoo Kim
swtbkim is on a distinguished road
First thing you need to specify is what you want to see.
If you need to check the temperature of air near the door, it is simple.
If you want to see the smoke or something, then things are going to be a bit more complex.
swtbkim is offline   Reply With Quote
Old   September 12, 2014, 08:28
Vishnu C
Hi, i need to estimate the CO2 concentration at different times.
Old   September 12, 2014, 08:38
Sangwoo Kim
Then fluent tutorial will help you.
Chapter 17: Using the Non-Premixed Combustion Model
Old   September 13, 2014, 10:15
Vishnu C
I managed to simulate for steady condition, but when i go to unsteady there is no ignition? should i change any boundary conditions?
fluent, heat simulation
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
How does FLUENT fair in absolute heat transfer analysis Steve Aboagye Main CFD Forum 1 August 31, 1998 13:12
