Problem, airflow in a duct with a steel grid inside? |
March 26, 2014, 12:25 |
Rep Power: 12 |
Hello!
I want to model an air flow in a duct with a steel grid inside so that I can observe the influence of the grid. I apply a pressure at the inlet and outlet. I modeled the grid with designmodeler. And I made a 2000 mm extrusion of a square that covers the grid, this extrusion represents the fluid. The fluid and the grid are well separated. When I do a simulation with Fluent, there is absolutely no difference with the case without the grid for the value of the static pressure at the output... I join you some pictures Could you help me please? |
March 27, 2014, 11:44 |
Rep Power: 12 |
By any chance, have you a suggestion? Maybe I have to do an interface? Or consider the grill as a porous medium?
How I have to do to consider an obstacle against a flow in a duct? |
March 28, 2014, 09:13 |
#3 | |
Rick
Rep Power: 27 |
If you set inlet and outlet pressures means that you already know what you're searching.... Daniele |
March 31, 2014, 06:00 |
Rep Power: 12 |
Hello, thanks for your reply.
I have to put an inlet pressure and outlet pressure so that I can observe the evolution of pressure in the duct, especially before and after the grill. But that's okay, I have changed the modelisation of my grill and it's much better. Thank you anyway ! |
cgns grid problem | praveen | SU2 | 20 | March 10, 2014 15:09 |
How to setup a new problem from a grid generated in ICEM | Tarak | OpenFOAM Running, Solving & CFD | 2 | September 29, 2010 13:26 |
problem about square duct. | Bin Li | Main CFD Forum | 0 | December 29, 2003 23:11 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 12:18 |
nonstaggered grid problem | Zhi-Xing Yu | Main CFD Forum | 7 | August 26, 1998 14:22 |
