March 8, 2014, 18:52 |
High aspect ratio
Jack Holmes
Rep Power: 12 |
Hi all,
I am trying to create a dynamic mesh but keep getting the error WARNING: The mesh contains high aspect ratio quadrilateral, hexahedral, or polyhedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm How do I fix this as when I preview my dynamic mesh I get a negative volume. Any help and advice would be great. Thanks all, Jack |
March 9, 2014, 16:14 |
Mack
Rep Power: 13 |
Hi Jack,
Are you using a structured or unstructured mesh? Are you using a low Reynolds approach? If yes, do not worry about this message, even though you can correct this repairing the wall distance via TUI (as stated in the error message). However, if you are using an unstructured mesh and a high Reynolds approach then you may have bad quality elements (very skewed ones). You must check your mesh when uploading it on Fluent. You can also smooth it, if this is the case. As your geometry is very simple I would recommend you to use a block structured mesh with an o-grid. Regards, Mack |
March 10, 2014, 06:26 |
Email
Jack Holmes
Rep Power: 12 |
Can i ask for your email and send you the mesh to see if theres anything you can do.
If not, no worries and thank you anyway Jack |
March 10, 2014, 16:00 |
Mack
Rep Power: 13 |
Hi Jack,
Sorry but I do not have Fluent/ICEM anymore. Did you take a look on the 2D cylinder mesh tutorial? |
March 12, 2014, 22:31 |
ganhai
Rep Power: 12 |
Hi,Mack
I also get into the same trouble with Jack.My model with unstructured mesh and big Reynolds approach. How can I improve my mesh quality . |
March 13, 2014, 18:40 |
Mack
Rep Power: 13 |
Hi Ganhai,
Have you tried to smooth the mesh? You can do it either on your meshing program or on fluent. If you check the mesh on fluent prior to the movement and everything is ok, then it means that your moving parameters are not ok. Do not forget to apply movement to the cylinder volume and not just to the walls. Take a look on the tutorial I mentioned before, it may help. Regards, Mack |
March 13, 2014, 21:14 |
ganhai
Rep Power: 12 |
Hi Mark,Thank you for your reply!Here i give my icem model for you.I really appreciate you can take some time have a look.
Thanks again. france |
March 14, 2014, 10:06 |
Mack
Rep Power: 13 |
Hi Ganhai,
Is that a hollow cylinder? Is it 2D or 3D? Sorry, but I could not understand your geometry with these pictures. It seems that you have very stretched elements, so you should try to square them increasing the number of cells on the edges. |
March 14, 2014, 20:48 |
#9 |
ganhai
Rep Power: 12 |
Hi,Mack
It is 3D and the surface of the up and down are sphere.If I increasing the number of cells on the edges the whole model will have several millions elements.Then my compute nearlly can't deal with it.So,Is there any way I can solve this problem. |
March 15, 2014, 11:08 |
#10 |
Mack
Rep Power: 13 |
Hi Ganhai,
Well, as your geometry is quite symmetric you can take advantage of this and simulate just a fraction of the domain. Try to simulate just a "piece of cake", applying symmetry condition to both sides. It will save you enormous computational effort. |
March 16, 2014, 21:18 |
#11 |
ganhai
Rep Power: 12 |
ok,Mack. I will try it.No matter how,I will let you konw the result.Thanks again.
dynamic mesh, fluent, high aspect ratio, negative volume error |
MUSCL shock capturing on high aspect ratio meshes | vijay_paul | Main CFD Forum | 1 | September 29, 2012 01:16 |
High aspect ratio | oort | OpenFOAM | 5 | September 16, 2011 15:06 |
High Aspect Ratio elements | Flavio | CFX | 2 | November 24, 2006 13:01 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
Aspect Ratio at high turbulent and swirled flows | zago | FLUENT | 0 | May 19, 2004 03:37 |
