January 18, 2014, 10:19 |
Fluid Structure interface - Negative Volume
Mohammad Cheikh
Hi I am doing a fluid structure interface simulation on ansys. I have a simple problem where I apply a sinusoidal pressure P=Pmax*sin(2*pi*fr*t) on a solid membrane and in turn the solid membrane will compress the fluid and the fluid pressure will increase. The time step I use is always = 1/20 of the period or 1/f.
I done this simulation with time step ranging from 0.1 to 0.005 and no problem occured, however when I apply smaller time steps the simulation would give me negative volume on the 3rd iteration. Can someone please explain why does the time step affect the defomration?? Thanks |
January 23, 2014, 13:35 |
Carl Schultz
Rep Power: 13 |
I am working with a sort of similar situation. This is a tip that I received from Ansys.
There is an rpvar in Fluent which you can use to slow down Fluent convergence- which will also damp out the pressure oscillations. This is: (rpsetvar 'dynamesh/sc-bc-compressibility-type 1) (rpsetvar 'dynamesh/sc-bc-compressibility 0.1) See solution #2022119 for more explanation on usage. Second parameter needs to be decided based on trial and error. The video in solution 2022119 goes through how to sort it out. Though, I haven't fixed my problem yet... |
January 23, 2014, 15:49 |
Thanks for the reply
Mohammad Cheikh
Thanks alot for your reply I applied what you told me and it worked.
Courant number blowing up, non-orthogonal mesh? | odellar | OpenFOAM Running, Solving & CFD | 5 | October 22, 2013 20:50 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
negative element volume (CFX-10.0) | CFDworker | CFX | 8 | September 27, 2011 19:16 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 03:39 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
