February 23, 2013, 11:59 |
Surface Reaction
Babak
Rep Power: 13 |
Hello guys,
I wanna simulate a surface reaction in FLUENT. However, the details of volumetric reaction for gas-phase and heterogeneous reaction are not in the literature. So, I am wondering if I can create this surface reaction by myself, introducing the Arrhenius parameters, activation energy etc. In other words, I would like to know whether or not I am able to create a reaction based on the global reaction? (without intermediate reactions) Thanks for your help Babak |
February 23, 2013, 16:52 |
#2 | |
Parisa
Rep Power: 13 |
Dear Babak, I had problem in simulation of surface reaction in FLUENT, for mixtures that I didn't have the details of chemistry mechanism. Did you check in CHEMKIN? In my case, CHEMKIN also doesn't provide that information. Also, I investigated a lot in literature but no gain. Is your problem similar to mine? Please share your experience with me if you got any success. Last edited by Parisa_Khiabani; February 27, 2013 at 15:19. |
February 23, 2013, 16:57 |
#3 | |
Babak
Rep Power: 13 |
Hello Parisa, Thanks for reading my post. Yes, seems my problem is partially similar to yours. Yes, I did check with CHEMKIN and this surface reaction is not covered in CHEMKIN as well. Like your case For sure I will keep you posted if I found a way to solve that. |
February 27, 2013, 15:21 |
#4 | |
Parisa
Rep Power: 13 |
Any update? |
February 28, 2013, 12:15 |
A-A Azarafza
Rep Power: 14 |
I suppose there's no any remarkable problem in setting a volumetric reaction both in gas or liquid phase. Regarding to heterogeneous reaction, I think you should use UDF for this purpose. Concerning to the second questions, you don't need to use intermediate reactions, only global would be OK. The procedure to set a Arrhenius reaction is simple and straightforward, you just need to have activation energy and pre-exponential factor and reactions exponent. There is a good tutorial about this. I think, CVD (Chemical Vapor Deposition) tutorial is good enough to help you to find your way to proceed further.
Good luck |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
Surface reaction source definition. | windhair | CFX | 0 | March 17, 2008 06:36 |
surface reaction | Jason | FLUENT | 2 | September 1, 2003 04:19 |
surface reaction rate plot at diffusiion limit cas | Jason | FLUENT | 1 | August 22, 2003 05:54 |
surface reaction | Jason | FLUENT | 1 | August 20, 2003 23:01 |
