particle time step size, number of time steps in DPMPM
Like Tree2Likes
Old   April 22, 2014, 09:21
ruturaj171 is on a distinguished road
Hi Amir sir
In my heat sink cooling problem actually I want relative humidity of 15% at the exit of the sink but I am getting it 7.42% , I tried with different combinitions of particle time step size and number of time steps. In this particular process I have given mass flow rate of 4.22e-7 and stop time of injection as 100s for every combinition, But still my rate of evaporation and hence RH is not increasing. (In my problem the relative reynolds number is 0, air velocity is 1 m/s). Can you suggest me a way to resolve the problem?
Regards
Ruturaj
ruturaj171 is offline   Reply With Quote
Old   July 3, 2014, 14:34
Hi amir sir
Actually I am able to validate results of one of paper by using DPM in FLUENT. I drawn geometry with symmetry boundary condition, but I was giving total mass flow rate through duct. But that mass flow rate must be half. So with excess mass my sink was getting overcooled. Because of your previous quick replies, I was able to understand various terms in fluent physically. Thanks a lot.
Old   July 29, 2016, 14:03
Default Particle status for DPM iteration
  #23
Sagar
ksgr is on a distinguished road
Hello
I have read the Fluent User guide and also have read the posts regarding this but I am not able to comprehend the unsteady particle tracking of Fluent. I am running unsteady simulations for continuous phase and also want to have unsteady particle tracking. In the particle treatment I choose unsteady and I also choose to inject particles with fluid flow time step. Till here its good but now it starts to get messy.
Firstly, if I want to inject particles at fluid flow time step why does it still asks about particle time step size and what is this parameter exactly?
Secondly, the time step size of my continuous phase is 1e-5 and I keep my particle time step size as 0.0001. When I run the simulation, Fluent recognizes the number of parcels but the status for the parcels it prints on the console is wierd.
Updating solution at time level N... done.
Injecting 31360 particle parcels with mass 5.375e-09 at t = 0
DPM Iteration ....
number tracked = 31360, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0
My question why the status of the particle is zero?
When I try to reduce the time step size of the continuous phase to 1e-4, the same 31360 particle parcels are tracked and gives proper status (in my case they are droplets and should evaporate).
The mass flow rate of the DPM phase is 0.5375 g/s and I inject 31360 particle parcels from injection file.
ksgr is offline   Reply With Quote
Old   November 2, 2016, 03:12
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Originally Posted by Amir View Post
No! The DPM equations are solved in unsteady fashion, but they can be considered in steady or unsteady flow fields. These two are different.
Nope. In each numerical analysis, you should assure the iterations are quite enough and increasing them any further wouldn't change the results. I don't see any proportion ....
You can take a look at any text book in this field; aerosols. For instance, this one:
"Aerosol Technology, William C. Hinds"
Bests,
Dear Amir,
I want to inject a fluid in my flow inside a nozzle that has gas in it, I used plain atomizer model. I am not sure about the diameter. What diameter should I choose?
Shamoon Jamshed is offline   Reply With Quote
Old   August 25, 2017, 09:16
Default particle time step size
  #25
ahmed elbanna
ahmed banna is on a distinguished road
hi every body, I have benefited from these fruitful discussions, and I reviewed the common resources those are explaining the DPM, and my convictions as follow
1- either you used unsteady or steady particle tracking, there will be a time advancing for the particle to find the trajectory. don't forget that the particle ODE's independent variable is the time(t).therefore, the 'steady' term does not mean the cancelling out of the time derivative.
2- the main difference between the unsteady or steady treatment of the particles is the timing of DPM source update to the continuous phase governing equations.
3- I think that the particle time step size and the number of time steps below the particle treatment are related to when should the DPM sources be updated to the continuous phase equations.
ahmed banna is offline   Reply With Quote
Old   August 25, 2017, 09:36
ahmed elbanna
Originally Posted by lili View Post
Dear Amir
And I want to know in discrete phase model panel what is the difference between length scale/step length factor (bellow the tracking parameters) which control time step size and "particle time step size" (bellow particle treatment) which appears when unsteady particle tracking is ticked.
Also in particle treatment field what does "number of time steps" means? In help said "When you increase the Number of Time Steps, the droplets penetrate the domain faster"???
indrajitpatil likes this.
Old   August 24, 2024, 15:27
Default use of number of time steps
  #27
indrajit
indrajitpatil is on a distinguished road
for an injection is this holds true (stedy state continuous phase - unsteady particle tracking)?
Iteration upto which injection will run = Total injection period specified in sec / (number of time steps * Particle time step size )
indrajitpatil is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
