Problem with example from the ANSYS UDF MANUAL
Old   September 23, 2010, 06:37
Default Problem with example from the ANSYS UDF MANUAL
Roman Gobitz-Pfeifer
Wikie is on a distinguished road
to get use to UDF-programming I start playing arround with the examples mentioned in the ANSYS UDF GUIDE. I copied this example:
#include "udf.h"
DEFINE_DPM_DRAG(particle_drag_force,Re,p)
real w, drag_force;
if (Re < 0.01)
drag_force=18.0;
return (drag_force);
else if (Re < 20.0)
w = log10(Re);
drag_force = 18.0 + 2.367*pow(Re,0.82-0.05*w) ;
else
/* Note: suggested valid range 20 < Re < 260 */
drag_force = 18.0 + 3.483*pow(Re,0.6305) ;
But it didn't work. My particles totally disappeared and I got this message. What is wrong with this code??
"chip-exec: particle_drag_force: argument 1: incorrect type (10): pointer expectedchip-exec: particle_drag_force: argument 2: incorrect type (38): int expected"
cheers
Wikie
Wikie is offline   Reply With Quote
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 08:51
Problem in compiling property(density) UDF satish2968 FLUENT 3 October 31, 2008 16:06
parallel UDF problem kerem FLUENT 2 June 20, 2006 07:56
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 07:49
Problem importing ANSYS mesh, please help Ankan Kumar FLUENT 1 February 2, 2003 09:38
