Temperature and Strain Rate Dependent Viscosity UDF Code
Old   March 28, 2022, 03:45
Exclamation Temperature and Strain Rate Dependent Viscosity UDF Code
SANDIPSINH
SANDIPSINH JODDHA is on a distinguished road
#include "udf.h"
#include "mem.h"
#define Q 145000 //J/mol
#define A 8.86e+6
#define n 3.55
#define R 8.314 //J/molK
#define alpha 0.045
DEFINE_PROPERTY(cell_viscosity, c, t)
real temp = C_T(c, t);
real mu_lam;
real Z;
real Flow_stress;
real x;
real strain;
if (strain < 0)
strain = 10;
else
strain = C_STRAIN_RATE_MAG(c, t);
Z = (strain)*exp(Q / (R*temp));
x = pow((Z / A), (1. / n));
Flow_stress = (1. / alpha)*(log(x + sqrt(pow(x, 2) + 1.)));
mu_lam = Flow_stress / (3.*strain);
if (mu_lam > 0)
return mu_lam;
we are trying to define the viscosity in term of strain rate and temperature using UDF code but, we are not getting value as expected.
SANDIPSINH JODDHA is offline   Reply With Quote
Old   March 31, 2022, 23:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you should specify what exactly is different from your expectations
compile the code and you will get following output:
warning C4715: 'cell_viscosity' : not all control paths return a value
warning C4700: uninitialized local variable 'strain' used
fix that
take into account that DEFINE_PROPERTY macro is a loop over all cells in domain, but your variable strain contains only 1 value for the last cell, it overwrites each other cell. You may use used defined memory to store strain on each cell
Also I would initialize strain for the 0-time moment
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   April 5, 2022, 12:48
SANDIPSINH
Can you please show us how to do that because I am new to this and when I try this code every cell get's same viscosity value.
ansys fluent, strain rate dependent, temperature dependent, udf code, viscosity
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Problem in convergence regarding constant viscosity and UDF related Viscosity. alexskerhut FLUENT 0 May 9, 2016 09:43
Problems in converging viscosity UDF dependent upon strain rate and temperature. alexskerhut Fluent UDF and Scheme Programming 1 March 17, 2016 08:19
Temperature dependent Non-Newtonian viscosity UDF cric92 Fluent UDF and Scheme Programming 0 April 14, 2013 07:31
