UDF Error at Node 0: Error code: 126
Old   January 26, 2020, 02:31
Default UDF Error at Node 0: Error code: 126
arash
a.maroofi is on a distinguished road
Hi gays,
when I build my udf I see no problem as you can see bellow, but when I load it, I see this message:
Opening library "C:\Users\Desktop\fluent\libudf"...
my computer work with windows 7, and VS 2010, fluent 19.0 on my system
any body can help me. I am very confused to waht do I do.
Copied C:\Users\Gigabyte\Desktop\fluent/C:\Users\Desktop\fluent\burner.c to libudf\src
** WARNING: Automatically switched to run in parallel -t1 mode. **
** Detected non-parallelized UDF usage, enabling parallel usage. **
** If you encounter any issues, please re-run with -t0 flag. **
************************************************** **************************Creating user_nt.udf file for 3d_host ...
(system "copy "D:\PROGRA~1\ANSYSI~1\v190\fluent"\fluent19.0.0\sr c\udf\makefile_nt.udf "libudf\win64\3d_host\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3d_host")# Generating ud_io1.h
************************************************** **************************Creating user_nt.udf file for 3d_node ...
(system "copy "D:\PROGRA~1\ANSYSI~1\v190\fluent"\fluent19.0.0\sr c\udf\makefile_nt.udf "libudf\win64\3d_node\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3d_node")# Generating ud_io1.h
Done.
a.maroofi is offline   Reply With Quote
Old   January 27, 2020, 07:03
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you are trying to load code, which was compiled on other system for other fluent version(most likely)
Recompile your UDF
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 29, 2020, 07:00
arash
Recompile your UDF
I recompile my udf but still exists problem. I become confused to what do I do
Old   January 29, 2020, 07:50
Default Name and location
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
It appears that you are trying to load from a wrong location. Look at the first message, name is given as C:\Users\Gigabyte\Desktop\fluent/C:\Users\Desktop\fluent\burner.c
It appears that libudf is not located in the same folder as case file; it is not necessary but if it is not the case, then you have to provide full path to load. Second, go inside libudf and check if it has .dll files inside 3d_host 3d_node folders. If not, then library is not compiled. If it exists, then just copy libudf to the folder where case exists, use only the name of the library while loading, and it should work. If it does not, then please share a complete message showing compiling and loading.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
How to obtain node values in UDF? Maciej FLUENT 0 October 23, 2006 09:10
UDF, NODE value sam FLUENT 0 August 21, 2002 09:44
Help: how to get node values with UDF? Dazhi Guo FLUENT 0 February 4, 2001 01:59
Node values on UDF??? Kamal FLUENT 1 December 10, 1999 11:37
