UDF for Pitching Wing
Old   April 26, 2015, 11:34
Default UDF for Pitching Wing
Arthur
artkingjw is on a distinguished road
Hello everyone!
I'm was wondering if you could simulate a changing angle of attack on a wing, without dynamic meshing - by simply changing the components of velocity to the inlet of the domain over time.
Unlike this thread, I am to study the effects of pitching/plunging motion on the airfoil. I have been told by my tutors that a UDF to vary the inlet velocity should do the trick, but I haven't found anything useful so far - mainly there is a lot of stuff on the velocity profile at the inlet, but not the direction.
I would appreciate any sort of guidance, thank you!
artkingjw is offline   Reply With Quote
Old   April 27, 2015, 05:40
`e`
`e` is on a distinguished road
Velocity is a vector quantity and therefore a velocity profile has both a speed and a direction. You'll need to have your inlet of type "velocity-inlet" and specify a velocity with components (each component, x, y and z has its own profile). Your simulation is transient and your inlet velocity is a function of time, therefore use the CURRENT_TIME macro to return the real current flow time [s]. Sounds like fun, let us know how you get on and if your results agree with literature!
`e` is offline   Reply With Quote
Old   April 27, 2015, 13:44
Arthur
Oh i didn't know that. I always thought that the velocity profile function was intended to prescribe a weird profile of velocity to your inlet? (Example of what I mean... ) As opposed to be able to do what I want... Interesting! I'll look deeper.
Old   April 28, 2015, 02:23
`e`
A profile used for boundary conditions (e.g. velocity profile) simply prescribes a value for each face of the boundary; this profile could be constant or otherwise a function of space or time. Your example of the pipe flow profile only has a nonzero speed in the axial direction (u) and therefore only requires an x-component velocity profile or a profile normal to the inlet boundary (parallel to the x-direction in your case).
Old   May 5, 2015, 01:50
Arthur
Update: I've changed my method, to instead use a UDF to define the angle of my airfoil. My airfoil is in a rotating mesh region, with an interface to a 'static' mesh. I seem to get it to work with constant angular displacement, but haven't got it running the way i wanted it to, with a driving function instead.
Varying the inlet velocity meant that my flow was hitting the walll - the wall effects were never really going away, so I had to find another way
How would you recommend doing the UDF of the rotating mesh then? what class of DEFINE_??? would that be? I'm thinking it would be an ADJUST one, with a CURRENT_TIME macro to check the time?
pitching airfoil, transient analysis, udf, velocity components
Use UDF to change the attack angle of flow over 3D wing nvtrieu Fluent UDF and Scheme Programming 8 June 26, 2016 06:53
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
flapping wing UDF code yahya_azizi Fluent UDF and Scheme Programming 1 July 24, 2012 07:24
DEFINE_CG_MOTION for flapping wing UDF xyzch001 Fluent UDF and Scheme Programming 0 December 14, 2011 09:39
DEFINE_GEOM UDF Problems Pat FLUENT 0 August 14, 2003 14:16
