June 6, 2014, 10:39 |
Interpreted: cannot execute cpp
Select One...
Rep Power: 14 |
Dear all
when I try to interpret 'file.c' I get the following message: error: udf compiler: cannot execute cpp I tried to put thick in 'use contributed CPP', but it does the same. Any ideas? Thanks for help |
June 11, 2014, 15:53 |
Vineeth C S
Hi eneja,
I had this problem a few days back. When I checked the folder .../ANSYS Inc\v140\fluent\ntbin\win64, I found the cpp.exe file to be missing. I replaced this file from another installation and the problem was solved. Hope this helps. Regards, Vineeth |
June 16, 2014, 07:53 |
#3 | |
Rep Power: 13 |
I also have the same problem and I would like to ask you a couple of things: 1) In the folder .../ANSYS Inc\v140\fluent\ntbin\win64 there should be a cpp.exe file? Because in mine one, there isn't any. 2) Where did you find this file elsewhere? PS. If it helps, I already have VS 2010 Professional. Thank you in advance. |
June 16, 2014, 12:20 |
Vineeth C S
The 'cpp.exe' file is part of every installation. However I have observed that some anti-virus programs tend to delete the file mistaking it to be threat. The simplest way you can fix this is by replacing the file from another fluent installation. Regards, Vineeth |
June 17, 2014, 10:13 |
#5 | |
Rep Power: 13 |
error udf compiler, interpreted udf |
Cannot Execute on Demand | Denis | Fluent UDF and Scheme Programming | 6 | June 26, 2018 05:40 |
Cannot execute cpp in UDF | bowling | FLUENT | 2 | January 5, 2018 12:05 |
fatal error while execute on demand... | fatemeh chitgarha | Fluent UDF and Scheme Programming | 1 | July 29, 2013 03:44 |
error while execute on demand | Anderson | Main CFD Forum | 4 | October 17, 2008 12:48 |
the Interpreted error | happyking | FLUENT | 0 | June 10, 2002 21:23 |
