Urgent UDF Problem ....
Old   May 28, 2013, 19:40
Exclamation Urgent UDF Problem ....
angelicapeygo
angelicapeygo is on a distinguished road
Friends,
I have a proble with my UDF. There is no problem about compilation and interpreting but I can not apply my udf to the boundaries. I get error message:
Error: cx-set-real-entry: wta[2] (float)
Error Object : ((constant .1) (profile """""")
Could you please help me about the case?
my UDF is like that:
#include "udf.h"
#define Tm 938
Domain *d;
DEFINE_PROFILE(wall_temp, thread, nv)
real T2solid=0.;
real T2liquid=0.;
real temp=0.;
real tmax=0.;
real tmin=0.;
real y=0.;
Thread *t;
cell_t c;
/* Loop over all cell threads in the domain */
thread_loop_c(t,d)
/* Compute max, min, volume-averaged temperature */
/* Loop over all cells */
begin_c_loop(c,t)
temp = C_T(c,t); /* get cell temperature */
if (temp < tmin || tmin == 0.) tmin = temp;
if (temp > tmax || tmax == 0.) tmax = temp;
end_c_loop(c,t)
printf("\n Tmin = %g Tmax = %g",tmin,tmax);
T2solid=Tm+100.0*y ;
T2liquid=Tm+40.0*y ;
begin_c_loop(c,t)
temp = C_T(c,t);
end_c_loop(c,t)
thanks alot....
angelicapeygo is offline   Reply With Quote
Old   May 28, 2013, 21:42
blackmask will become famous soon enough
Why do you use DEFINE_PROFILE(name, thread, nv) if your functions body does not involve 'thread' at all?
blackmask is offline   Reply With Quote
Old   May 29, 2013, 07:11
angelicapeygo
what do you advise me to do? I am new with the UDFs ..
Old   May 29, 2013, 07:16
It depends, DEFINE_ON_DEMAND or DEFINE_EXECUTE_AT_END could be an option.
Old   May 29, 2013, 07:29
angelicapeygo
I changed it to DEFINE_ON_DEMAND but the result is same. what can be the other reason :S
Old   May 29, 2013, 07:36
You Domain pointer are not initialized. Add a line
d = Get_Domain(1);
Old   May 29, 2013, 07:49
angelicapeygo
I realized it and add it but nothing changed.
vprofile.c
UDF for specifying steady-state temperature profile boundary condition
#include "udf.h"
#define Tm 938
Domain *d;
DEFINE_ON_DEMAND(wall_temp)
real T2solid=0.;
real T2liquid=0.;
real temp=0.;
real tmax=0.;
real tmin=0.;
real y=0.;
Thread *t;
cell_t c;
d = Get_Domain(1); /* Get the domain using Fluent utility */
thread_loop_c(t,d)
begin_c_loop(c,t)
end_c_loop(c,t)
begin_c_loop(c,t)
temp = C_T(c,t);
end_c_loop(c,t)
Old   May 29, 2013, 07:53
Replace
printf
with
Message0
Old   May 29, 2013, 08:01
angelicapeygo
it says:
CX_message not found. Do you know the reason?
thanks alot.
Old   May 29, 2013, 08:06
Then simply comment out that line and try again. If the error still persist, then I suggest you save you case, restart FLUENT and reread the case file.
Old   May 29, 2013, 08:11
angelicapeygo
it still does not work ..
do you think the other parts of my UDF is correct?
thanks alot.
Old   May 29, 2013, 10:27
I think the UDF is fine.
Old   May 29, 2013, 10:29
Jim Knopf
JimKnopf is on a distinguished road
What is the current error?
Printing is done via:
double var = 0.;
Message("text %g",var);
found one:
#define TM 938
is not really the same then defining a global variable. If you really sure that you what to define a global constant you should use:
static const double var = 4.5;
But still remind that global variables are bad and evil
Greetz
Jim
JimKnopf is offline   Reply With Quote
UDF Problem ozgur Fluent UDF and Scheme Programming 18 January 17, 2016 15:40
Pressure profile UDF for unsteady-state problem? Mohsen Keshavarzian FLUENT 2 August 20, 2008 05:22
parallel UDF problem kerem FLUENT 2 June 20, 2006 07:56
Switch problem! using 2 custom udf laws at the same time HP FLUENT 0 September 15, 2004 10:48
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 11:22
