Modify velocity profil using udf or without
Old   July 10, 2012, 14:49
Default Modify velocity profil using udf or without
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
hello everyone,
I wanna know if this is possible using Fluent:
Can we force fluent to change a velocity profil and make it more look like this:
What i'm trying to do is actually to simulate the presence of plasma actuators...
Thanks a lot for advance.
More about plasma actuators are here:
I know fluent is made to solve navier-stockes equations, i majoring in fluif mechanics, my knowledge in electricity is very limited. What do i need to simulate actuator ? maxwel equations ??? can we implement them via UDF ??
Thanks a lot again
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 10, 2012, 17:27
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Defining velocity profiles with a UDF is quite easy.
The UDF manual has all the information you need.
Concerning the plasma actuators: this is the first time I heard of this, but as far as I can see, it simply introduces a momentum source to the fluid.
Again, such a source can be modeled with a UDF (search for DEFINE_SOURCE in the manual)
flotus1 is offline   Reply With Quote
unsteady inlet velocity udf jill FLUENT 8 February 10, 2015 07:04
Velocity profile UDF egge24 Fluent UDF and Scheme Programming 2 May 10, 2012 14:03
UDF for velocity profile egge24 Fluent UDF and Scheme Programming 0 April 4, 2012 20:57
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 19:29
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 13:20
