Transport properties of the mixture in a bipropellant injector |
January 18, 2021, 09:56 |
Caio Roberto Sanches Florencio
In the blue injector, oxidizer with density rho1, surface tension s1 and dynamic viscosity mu1 flows , while in the red, fuel with density rho2, surface tension s2 and viscosity mu2 flows. A region for mixing these two substances exists as shown in the figure https://ibb.co/Gt0HMXX https://ibb.co/t3BSKC6. Given that the oxidizer (nitrous oxide) and fuel (ethanol) are miscible, I would like to know the mean value of the transport properties (density rho3, surface tension s3 and viscosity mu3) of mixture in that region.
First I tried to simulate only the flow in the oxidizer injector, in other words, no mixture. I chose the multi-phase and VOF models* , because besides the oxidizer, air is present too and appears as an air core in this kind of problem (swirl flow). The results of this simulation seemed reasonable to me. So the next step would be the simulation of the real problem. I applied the same logic to the problem with three substances (air,oxidizer and fuel), but the solution didn't converge. Now we have three phases and FLUENT asks as one of the inputs the surface tension of oxidizer/fuel which I don't know (the other two are surface tension of the oxidizer/air interface and fuel/air), so I inserted the value zero. About the theoretical background, I reviewing/studying the Cengel's fluid mechanics book, but it does not contain a description of multi-phase flows, so if you guys have some recommendations of books about this and the models used in the swirl flow,I'll appreciate it. Last edited by caiorsf; January 18, 2021 at 11:35. |
May 13, 2021, 13:27 |
Kerala
Rep Power: 5 |
Hi, we are dealing with a similar kinda problem(bipropellant coaxial swirl injector). Do you mind sharing the steps to solve this. We are trying to simulate with liq Oxygen and kerosene and trying to find the breakup length and SMD.
May 19, 2021, 01:48 |
Kerala
Rep Power: 5 |
Hi Caio, thanks for the reply.
email: 17me017alle@ug.cusat.ac.in |
May 20, 2021, 14:20 |
Kerala
Rep Power: 5 |
This probably requires a VOF to DPM transition model.
create constant transport properties for multi region case | Kumudu | OpenFOAM Pre-Processing | 3 | January 25, 2023 07:05 |
Mixture averaged/Multicomponent transport in openFoam reacting flow simulation | sahmed | OpenFOAM Running, Solving & CFD | 1 | March 5, 2017 02:21 |
defining nacl properties in a one phase mixture | galasinus | Fluent Multiphase | 1 | January 21, 2016 13:52 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 12:44 |
transport properties of gases | cfd sutdent | Main CFD Forum | 2 | April 29, 2004 10:41 |
