Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
The way of information transfer between Fluent solver and udf
Old   June 6, 2019, 02:33
Smile The way of information transfer between Fluent solver and udf
Jim
CrystalEternity is on a distinguished road
Now I'm a little confused about how the two are passed on,especially vectors.
For example ,this is an UDF macro from FLUENT help .
/* UDF for computing the magnetic force on a charged particle */
#include "udf.h"
#define Q 1.0 /* particle electric charge */
#define BZ 3.0 /* z component of magnetic field */
#define TSTART 18.0 /* field applied at t = tstart */
/* Calculate magnetic force on charged particle. Magnetic */
/* force is particle charge times cross product of particle */
/* velocity with magnetic field: Fx= q*bz*Vy, Fy= -q*bz*Vx */
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
real bforce=0;
if(P_TIME(p)>=TSTART)
if(i==0) bforce=Q*BZ*P_VEL(p)[1];
else if(i==1) bforce=-Q*BZ*P_VEL(p)[0];
else
bforce=0.0;
/* an acceleration should be returned */
return (bforce/P_MASS(p));
About this macro,I would like to raise the following questions:
1.How does i identify and allocate variables
2.The explanation about I is that it represents the components in cartesian coordinate system, 0, 1 and 2 can be taken.When the variable is passed and calculated(especially vectors), is it done once or many times?
For example,When the UDF is called, a certain velocity component is obtained from the solver, and the acceleration in the direction is returned. By calling the macro three times, three returns are returned to realize the effect of lorentz force on the particle, or are there other explanations?
CrystalEternity is offline   Reply With Quote
Old   June 8, 2019, 22:59
Jim
Is there anyone who can help answer these questions
fluent, information transfer, udf
UDF to record FLUENT Solver variables... mariachi Fluent UDF and Scheme Programming 11 September 24, 2019 01:07
Fluent UDF for thermal NOx larsschwarzer Fluent UDF and Scheme Programming 1 July 18, 2014 09:39
How to disable a specific solver in FLUENT by UDF? r.mojtaba Fluent UDF and Scheme Programming 0 July 8, 2013 14:44
UDF to record FLUENT solver variables... mariachi FLUENT 1 February 3, 2010 23:18
What's a UDF? Farooq FLUENT 5 December 9, 2003 07:52
