SolidWorks FloEFD, Global Variables in Parametric Study |
March 9, 2016, 07:45 |
Rep Power: 10 |
I have made a geometry which I will do an external analysis on. It is defined by 3 global variables I would like to do a parametric study on (In total 12 different geometries). I have tried inserting these into a design table, but found out you can't put global variables into a design table. I have also tried the "Add dimension parameter" but nothing happens and no dimension is able to be selected as a dimension paramter. Does anyone know what I can do for this? Or how to use the dimension parameters correctly? Thanks |
March 11, 2016, 08:14 |
Rep Power: 10 |
Just giving an update, I figured out a decent solution to the problem.
I have in the parameters variation selected each dimension I used the global variable on (essentially i didnt need them as global variables). I could then group them, so I only needed to change variation once. This was particularily handy in my linear pattern dimension, where i had both the step and number of patterns changing. I could group both of them and it would variate them both at once. The bad side about this is that I had one dimension which requires the computational domain to change (i have periodic boundary conditions). So for this dimension I made different configurations for each. In the end I made 3 configurations with 80 scenarios each. This is much less work then the 12 configurations with 20 scenarios each which I would have used otherwise! |
Parametric study by Ansys Workbench | Sahar FaPerhu | ANSYS | 17 | August 23, 2017 04:29 |
Parametric Study - Multiple Configurations in ANSYS CFX | kskong | CFX | 1 | June 7, 2016 09:22 |
Parametric Study | victoryv | FLUENT | 3 | January 31, 2013 21:29 |
Creating many def files for parametric study | Chander | CFX | 5 | April 2, 2012 11:48 |
Parametric Study | Murat | FloEFD, FloWorks & FloTHERM | 1 | October 13, 2008 04:20 |
