wall function
Like Tree10Likes
Old   March 24, 2012, 00:37
Default wall function
Studentdrak is on a distinguished road
"The basic idea behind the scalable wall-function approach is to limit the y* value used in the logarithmic formulation by a lower value of 11.06 is the intersection between the logarithmic and the linear near wall profile"
These are the statements from help files of cfx.
The lower limit of y* is restricted to 11.06,does this mean that the linear near wall profile is neglected?
"Do not use Standard Wall Functions unless required for backwards compatibility."
what is backward compatibility?
I am trying to simulate a heat transfer problem, how does scalable wall function affect the results?
my
Studentdrak is offline   Reply With Quote
Old   March 25, 2012, 07:48
No, just that the logarithmic approach is not used below y+=11.06, it transitions to the integrate to the wall approach.
http://en.wikipedia.org/wiki/Backward_compatibility
Scalable wall functions are your best chance of getting a wall function which works well regardless of having a fine or coarse mesh. Standard wall functions requires the user to mesh appropriately for the wall function approach you intend to use.
Old   March 25, 2012, 09:58
Thanks Glenn.
Would u pl. explain me how does doubling and quadrupling the number of nodes(for grid independent study) and scalable wall function work together?
Old   March 25, 2012, 18:59
Most CFD packages use standard wall functions, and these are only valid for y+>11 or so. So if you start off with a mesh with y+=30, then half the mesh element length you get y+=15 (so far so good) but the next refinement gives you y+=7.5. The standard wall function approach is not valid for this value of y+, so you will get a finer mesh solution but it will not be physically correct as you are applying inappropriate wall functions.
The scalable wall functions help here because as you refine to below y+=11 it transitions to integrating to the wall. This keeps the wall functions physically valid and means you can do mesh refinement more easily.
Old   March 26, 2012, 00:09
Thanks again Glenn.
As i understand, the Scalable wall functions are better to use for grid independent study also. is this correct?
Old   March 26, 2012, 00:12
Isn't that what I just said?
Old   March 26, 2012, 04:21
Thank u Glenn
Old   March 26, 2012, 05:53
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
No. Below Y+ = 11.06 mesh points are ignored. If you check the mathematical formulation of scalable wall function you will not find any term for linear profile. Therefore scalable wall function are not built for resolving the viscous sub layer. For that you have to choose the automatic wall treatment which is only available in k-omega based models.
Transition to linear profile is property of hybrid wall functions (aka automatic wall treatment in CFX)
Scalable wall function are designed to avoid the problems
1. With mesh refinement when Y+ goes to 1. In this case standard wall function approach ceases to be valid.
2. At separation when velocity is zero and Y+ is again very low, in this case standard wall function ceases to be valid.
In other words scalable wall function is robust wall function as compared to standard wall function.
Standard wall functions are also valid up to Y+ = 11.06 and it was the default option in Fluent when Y+ is higher than 11.06. See the SA model section of Fluent User guide (I know this is CFX forum )
Far is offline   Reply With Quote
Old   March 26, 2012, 06:01
Thanks for the correction Far. I have just read the documentation to confirm this time
Scalable wall functions effectively limit the y+ to 11. When y+<11 it sets y+=11 and therefore assumes the first node is outside the log layer.
Automatic wall functions are what I was confused with, they transition from wall functions to integrating to the wall over the y+=11 threshold.
Far likes this.
Old   March 26, 2012, 06:04
Far
Sijal
I have learned many things from you.
Old   March 26, 2012, 08:06
Thank u Glenn and Far,
Does this mean that for forced convection heat transfer problem K epsilon - scalable wall function are not correct to use?
Old   March 26, 2012, 19:00
It is rare that a turbulence model is "right" or "wrong". They are all different with different strengths and weaknesses.
But in general the SST turbulence model is the default choice. It allows easy extension for some advanced models like automatic wall functions, curvature correction, transition model and others. k-e I would only recommend if you are comparing to published data, it is largely superseded by SST in my opinion. RSM should be considered then anisotropic turbulence is significant, and LES style models (inc SAS, DES) for when you have large scale vortex shedding which you need to resolve.
lth likes this.
Old   June 28, 2012, 10:45
Default Standard wall function and SAS model
  #13
Mina
Mina_Shahi is on a distinguished road
Hi ghorrocks
You told When y+<11 it sets y+=11 and therefore assumes the first node is outside the log layer, you mean for y+< 11 it assumes u+=y+ (linear approach)?
in CFX when you select SAS-SST model it automaticly selects standard wall function , while from your discussion i learned that scalable wall function is a better choice. However i can't do anything for that because it will be selected automaticly. so in this case (standard wall function) i have to take care of the mesh and should refine it well close to the wall, am i right?
the y+ in my geometry (a combustor) is changing in the range of y+<40. so can you please tell me according to this wall function (standard) and this turbulence modell (sas-sst) which i used my mesh is good enough close to the wall?
Regards
Mina
Mina_Shahi is offline   Reply With Quote
Old   June 28, 2012, 12:24
Far
Sijal
Originally Posted by Mina_Shahi View Post
Hi ghorrocks
Regards
Mina
It is the log law of the wall. There is option of choosing the standard wall function, but default is the scalable wall function for epsilon based models. For omega based models the default choice is automatic wall function.
Old   June 28, 2012, 16:21
Mina
Thanks Far!
1- in CFX the default for the sas model is standar model. But what is your idea about the range of y+ in my mesh? is it fine enough?
and how does the software take care of y+<11?
2- how can we know for a certain turbulence model how big y+ can be or how much it can vary?
Regards
Mina
Old   June 28, 2012, 19:29
I am not sure what wall boundary conditions SAS uses, you will have to look that up.
Not only do different turbulence models have different requirements but different flow regimes have different requirements. So the only way to be sure is to do a mesh refinement sensitivity study on your configuration.
Mina_Shahi likes this.
Old   June 29, 2012, 07:03
Mina
Thanks
But can you explain what happens for y+<11 (in standard wall function)? I guess that turbulence equatuion will be integrated untill the wall in th eregion with y+<11, Is that true? or simply for the small y+ it assumes u+=y+ (linear approch and not logaritmic approach)? i am a bit confused with this layers
Old   June 29, 2012, 08:52
If you are using standard wall functions then the wall function equation will be used regardless of y+. Refer to the CFX documentation or a turbulence textbook like Wilcox for details on this. But the key point is that the wall function equation is only applicable from around y+>11. So if you apply standard wall functions with y+<11 then you are simply applying them in a regime where they are not accurate.
Old   June 29, 2012, 09:49
Far
Sijal
Actually there is change in definition of u+. so instead of u+, u* is used for the scalable wall function. see documentation.
Old   June 29, 2012, 09:54
I think the question was what happens for standard wall functions.
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 08:22
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Need some wall function approaches! yka8150 Main CFD Forum 0 September 22, 2009 00:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
