primitve 2D regions in CFX
Old   September 4, 2008, 20:24
Default primitve 2D regions in CFX
shrimp
Hi guys,
I generate tetra+prism mesh in ICEM. But when I import it into CFX 11, I found that some of my surface that I set in ICEM disappeared, and many primitive 2D regions showed up! does anybody have any idea on this? Thanks a lot!
Old   September 5, 2008, 00:04
Default Re: primitve 2D regions in CFX
Farid
Did you "associated Geometry with Mesh" after creating surface in ICEM?
Old   September 5, 2008, 15:14
Rikio
I met this before, and i would re-generate the mesh. Sometimes it will work. I did not know why this happen. So searching answers with u
Old   September 5, 2008, 18:32
shrimp
thanks for your guys' reply. Farid, what do you mean by ?associate Geometry with mesh". I just created surface, repair geometry, and then generate tetra mesh. Actually, I set 3 material points and 2 interfaces. The primitive 2D regions in fact belong to the interfaces.
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 12:08
Solution technique/ Mesh type/ Cell limit/ Multi-zone regions in CFX zandi CFX 5 April 10, 2009 02:06
Obtain Geometry Data from a Grid File in CFX 10.0 ARJUN CFX 2 August 17, 2006 08:20
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 12:59
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 05:47
