April 16, 2008, 12:12 |
Annular flow
I have flow in an annulus. The flow enters perpendicular to the annulus and exits perpendicular also. The behavior I am seeing is when I vary the nozzle size, 2",4",6", I am obtaining counter-intuitive results. With the larger diameter nozzles at the entrance and exit, I am receiving larger pressure drops. It would make sense that the smaller the diameter, the higher the pressure drop. I've tested both constant velocities and constant volumetric flow rates through the various size nozzles. I have also obtained k-values (minor loss coefficients), and can accurately predict the pressure drop varying flowrates, but again still counter-intuitive with respect to nozzle diameters.
Is there some anomaly with annular flow that causes this or is something inherently wrong with my models? If anyone has any insight, it would greatly be appreciated. Thanks. |
Annular Flow liquid-liquid | Anf893 | FLUENT | 0 | May 3, 2011 18:58 |
Annular Flow in Pipes | metro | OpenFOAM Running, Solving & CFD | 0 | August 11, 2010 04:34 |
ANNULAR FLOW MODELLING | İbrahim Utku Başyazıcı | FLUENT | 0 | April 17, 2006 05:07 |
regarding flow analysis in annular combustion cham | aryan | FLUENT | 0 | March 1, 2006 23:55 |
gambit mesh generation for core annular flow | anand | FLUENT | 0 | November 17, 2005 03:33 |
