Problems with running a new downloaded ANSYS strident 2021 R2 |
June 1, 2022, 11:15 |
AH
CFX isn't running, something to do with setup and most likely I got something wrong, but can anyone help me fix this? Please, see also attached screen dump.
| ERROR #001100247 has occurred in subroutine . | | Message: | | | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked | | out: | | | | ANSYS CFD Solver | | | | Please carefully examine the error message output above and check | | that: | | | | 1) The license server is specified correctly and is running. | | | | 2) An appropriate license is available for checking out. | | | | These problems can be checked using the ANSYS Client ANSLIC_ADMIN | | utility. For further troubleshooting information please consult | | ANSYS, Inc. Licensing Guide. |
June 1, 2022, 20:07 |
Rep Power: 144 |
Doesn't the error message tell you exactly what the problem is? Have you read the error message?
It cannot get a license. You have run out of licenses, your license server is not working or your machine cannot connect to the license server. Look in the ANSYS installation and licensing manual.
June 2, 2022, 08:12 |
AH
Yes I have read error messages, tried a few things. However it started working the following day, don't ask me why. Thanks for your reply.
July 3, 2022, 08:23 |
AH
This problem is back again, CFX solver not running with the same error message as shown above.
Dont know how to fix it. |
July 3, 2022, 08:46 |
Rep Power: 144 |
You have a licensing problem, like I said last time. The error message says exactly what the problem is.
There are many possible reasons - somebody else got the license, the license server is down, the network connection to the license server is down, you are requesting a license you do not have or many other reasons. You are going to have to fire up the Client Licensing thing and work it out. Check the license server is up, check the necessary licenses are available and so on. If you cannot work it out and you have a commercial license then contact ANSYS licensing support.
July 8, 2022, 14:52 |
AH
It is a student version, it works sometime, not always.
Error Running Design of Experiments in ANSYS Fluent | tytrzecki | FLUENT | 0 | April 22, 2018 16:01 |
ANSYS stack trace error when running 2-way FSI in command line | raz | ANSYS | 0 | June 6, 2017 08:31 |
Ansys stutent version problems | Czoklyt | ANSYS | 1 | January 31, 2017 17:16 |
ANSYS Licensing Problem, Processes Running but Showing as Not Running | penguinman | ANSYS | 3 | September 27, 2016 14:30 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 04:17 |
