about advance turbulence controlin CFX5.6
Old   April 23, 2007, 22:07
Default about advance turbulence controlin CFX5.6
akang
Hi, everybody, can any of you tell me that if CFX5.6 has the advanced turbulence model control as in CFX10 and how can I set or modify them? Thank you!
Old   April 24, 2007, 09:53
Default Re: about advance turbulence controlin CFX5.6
opaque
Dear akang,
The Advanced turbulence model control were not available in the 5.6 release .
Several of the current advanced control were hidden as expert parameters, and other did not even exists.
Which one are you looking for?
Opaque.
Old   May 1, 2007, 23:24
akang
Dear Opaque, Thank you for your reply. I want to know Whether I can modify the turbulence model constants. akang
Old   May 2, 2007, 15:59
opaque
Dear akang,
I am sorry.. for which model?, and which constants?.. Not all of them were available to the user..
Opaque..
Old   May 4, 2007, 06:08
akang
Dear Opaque, If the k-Epsilon turbulence model? akang
Old   May 4, 2007, 12:31
opaque
Dear akang,
OK.. it is the k-epsilon model. Which constants in the k-epsilon model do you want to change using the 5.6 release version?
Please as specific as you can be, on which model constant you need.. Just a heads up.. They will not support CEL expressions at all since they were expert parameters back then.
Answering "All" is not a choice..
Regards, Opaque.
Old   May 5, 2007, 07:29
akang
Dear Opaque, Thank you for your reply very much! Can Cmiu,Sigma_k,Sigma_epsilon,C_epsilon1 and C_epsilon2 be modified? Or just some of them can be modified? Thank you again!
akang
Old   May 7, 2007, 10:03
opaque
Dear akang,
Below is what you need to modify those models constants you mentioned.. This only worked up until 5.6.. Latest releases do not support these parameters.
I am very skeptical of modifications of the model coefficients by those who are not turbulence modeling experts since there are quite a few relations between the coefficients themselves to satisfy some physics. If you know what you are doing, good luck.
Opaque.
FLOW: EXPERT PARAMETERS:
cmu turbulence model constant = 0.09
ce1 ke model constant = 1.44
ce2 ke model constant = 1.92
sigmak ke model constant = 1.0
sigmae ke model constant = 1.3
END END
Old   May 9, 2007, 07:30
akang
Dear Opaque, Thank you very much! If I get some interesting results, I'll share them!
akang
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
Creating Turbulence zel0 Main CFD Forum 1 November 16, 2009 02:25
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Is turbulence disripable by chaos? Matthias Main CFD Forum 9 March 27, 2001 14:04
