Pump design point error
Old   June 19, 2021, 09:00
Default Pump design point error
Mohamed911 is on a distinguished road
Hello everyone,
I'm working on 4 parts axial pump (Inducer, rotor, diffuser, straightener), and to minimize the calculation time, I tried to used design point to get the pump efficiency and the head pressure at different rotational speeds:
Parts:
Inducer: S1
Rotor: R1
Diffuser: S2
Straightener: S3
Pressure Head:
massFlowAve(Total Pressure in Stn Frame )@S1 Outlet - massFlowAve(Total Pressure in Stn Frame )@S3 Inlet)
Torque: (J)
torque_z()@R1 Blade
Density: (Kg/m^3)
massFlowAve(Density)@Inlet
Flow rate (m^3/s)
massFlow()@S3 Outlet / areaAve(Density)@S3 outlet
Angular velocity (rad/s)
-7000 [rev/min]
Efficency
(Flow rate * Pressure head) / (Torque * Angular velocity)
at the design point, I used 4 angular velocities (7000,10000,12000, and 15000). however, when I update them I get a constant pressure head and a constant torque at all point
If you have any ideas on how I fix it or if the equations I used are wrong.. please let me know
Thank you
Mohamed911 is offline   Reply With Quote
Old   June 20, 2021, 20:15
FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
In your case, as the pressure head is the same at all points, I would look at how you define pressure head and how you have defined the simulation boundary conditions.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 21, 2021, 06:10
the boundary conditions I'm using are:
Inlet :static pressure (60 mmHg)
Outlet: Mass flow rate (0.0875 kg/m^3)
Walls: No-slip
Turbulent: k-e stard model
Ps: inelt area = outlet area
Old   June 21, 2021, 06:35
You cannot debug this from the few inputs you attach. You have to look at the details of how you set it up and how the solver worked. You cannot do this over the forum. You need to do this yourself by looking at the details.
Old   June 21, 2021, 13:51
the conditions I'm using are all correct, I already did all simulations using the same condition and the pressure head is variating (at the same flow rate, the pressure head increases when we increase the angular velocity)
Old   June 22, 2021, 09:00
Opaque will become famous soon enough
Get two output files for different design points, and compare them side by side, and try to understand any difference, or too many "coincidences"
That is one way to understand how many different calculations you really did, not how many you submitted.
Opaque is offline   Reply With Quote
Old   June 23, 2021, 06:28
I did it. I used the same equations in every simulation manually, and I did get different pressure heads and different efficacy.
the problem is that I had to do all the simulations individually
Old   June 23, 2021, 09:01
You will find the experienced CFX users on the this forum rarely use CFX inside workbench, but use it stand-alone. The link between CFX and workbench is not reliable sometimes and you full control of what the solver is doing. It appears you have just found this same problem.
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
