CFD-Post results analysis
Like Tree1Likes
  • 1 Post By ghorrocks
Old   April 28, 2021, 17:01
Default CFD-Post results analysis
Edgar
Edgar Yako is on a distinguished road
I have simulated a radial compressor within ANSYS by firstly using VISTA CCD and consequently transferring the data into Turbomachinery Fluid Flow. Here, BladeGen creates the 3-D model of the radial compressor, turbogrid creates the mesh and finally CFX provides the results.
My question is regarding some of the different results that CFD-post automatically generates and wanted to know whats the difference between them. The attached pictures are below. What would be the difference between these 3? (Span 10,50,90 view)
https://imgur.com/7WjAX86
https://imgur.com/xFBwElM
https://imgur.com/lpfmfNv
Also, what do you think of these results? These gave an isentropic efficiency of 86% and a pressure ratio of 4.7 overall but I want to understand whether these velocity distributions along the suction and pressure side are reasonable or they do not look efficient.
I will also add a blade-to-blade view image in case its required.
https://imgur.com/lGBvNKz
Thanks in advance
Edgar
Edgar Yako is offline   Reply With Quote
Old   April 28, 2021, 19:41
Please post images directly on the forum. Do not use third party sites. See FAQ: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
About accuracy, see FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
On interpreting your results - I have no idea what you are modelling, what conditions you are modelling or what the images show. This means I cannot make any useful comment about what your results are.
aero_head likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   April 29, 2021, 06:20
Edgar
Sorry I should have been clearer with my modelling.
I am trying to design a radial compressor that achieves a reasonable isentropic efficiency. The specifications added to Vista CCD are the following:
Duty and Aerodynamic Data Tab
Overall Pressure ratio :4.5
Mass flow rate : 0.2 kg/s
Rotational Speed : 150000 rpm
Temperature inlet:293.15K
Pressure : 101000 Pa
Isentropic Efficiency: 0.8
(Everything else left default)
Geometry Tab
Hub diameter : 20 mm
Shroud Diameter : Optimized diameter
Number of vanes : 7 (for both main vane and intervane)
After setting up Vista CCD, I transferred the data into Turbomachinery Fluid Flow which is a pre-built program within ANSYS that automatically generates the mesh using Turbogrid (it is a hexahedral mesh with 250000 total nodes), consequently, it uses CFX to set the parameters for simulation and finally the results are obtained on CFD-Post. The results I have shown you are obtained within CFD-Post and there are different tabs that are automatically generated. However, I was not sure why there are 3 different types of results (Span 10/50/90) and wanted to know what these referred to.
If you need anything else in particular to continue please let me know. Also, do you need me to re-submit the images or can you use those links?
Post Processing Results: Ansys Workbench 18.2 - Fluent - CFD Post - Porous Body onlycfd CFX 4 April 29, 2021 04:02
Fluent export - CFD Post - Airfoil Results Wingman ANSYS 0 November 18, 2016 17:36
CFD Online Celebrates 20 Years Online jola Site News & Announcements 22 January 31, 2015 01:30
CFD Post. Multiple results comparison zombiaska Visualization & Post-Processing 1 December 23, 2014 17:06
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 09:37
