Oscillation of residual and monitoring points |
William
Rep Power: 6 ![]() |
Hello.
I'm trying to simulate the full-scale heat exchanger using porous media approach to the core part. So I modeled the whole heat exchanger and tried the simulation. As I attached a picture, the residual and user monitoring points keep oscillating, do not converge. In order to ensure the convergence, I have set the timescale factor to 0.1s (especially in the picture 0.01s) but it doesn't converge well. I have searched how I can ensure the convergence in CFX, but most of the posts are said 'timescale factor', but it doesn't work well. Does anybody have an idea of convergence? I think I must make this simulation converge. Thank you in advance. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
There is a lot more to do beyond just the time scale factor. See the FAQ for details.
buoyantSimpleFoam and watertank | Tobi | OpenFOAM Running, Solving & CFD | 100 | December 18, 2022 09:15 |
a problem with convergence in buoyantSimpleFoam | skuznet | OpenFOAM Running, Solving & CFD | 6 | November 15, 2017 13:12 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 22:33 |
should Courant number always be kept below 1? | wc34071209 | OpenFOAM Running, Solving & CFD | 16 | March 9, 2014 20:31 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
