August 11, 2006, 04:48 |
friction & windage
hi, I am modelling a rotating machinery by using the MFR CFX option. I have to compute the friction and windage of this machine. The rotation axis is z. To determine the friction and windage ( ie torque * rotating velocity), i have to find, in the CFX post, the torque_z()@"rotating part". Rotating wall's torque are negative value. if i compute the static wall's torque, some value are >0 and some other value are <0. It's very strange!! How can i find the friction and windage by using CFX post? I don't know if i have to consider the torque on stator. I don t understand the positive torque on some stator's wall?
best regards Alex |
August 14, 2006, 07:21 |
Re: friction & windage
Alex
Did you have a look at the rotation direction? Is this the cause for +ve and -ve torgues ? GT |
August 16, 2006, 04:00 |
friction & windage - how to determine it with post
i understand that torques could be positive or negative values for the rotor (sign depends on the rotation direction). But, for the stator, some value are positive and some others, are negative. That is very strange. Also, i don't know how can i evaluate the friction and windage using cfx post.
caculation of friction factor | Dilip | Main CFD Forum | 9 | February 23, 2016 06:00 |
Skin friction in fluent is wrong | syler3321 | FLUENT | 2 | March 24, 2011 09:05 |
Openfoam friction coefficient differences. | Peter88 | OpenFOAM Post-Processing | 0 | February 8, 2011 11:07 |
friction & windage losses prediction - help needed | alex | CFX | 0 | August 28, 2006 10:51 |
Compute Skin friction coef by hand | Francois | FLUENT | 1 | February 10, 2006 07:21 |
