CFX Simulation of flow in a Pump
Old   March 19, 2020, 19:03
Cool CFX Simulation of flow in a Pump
Calvin Stephen
stephec1 is on a distinguished road
I have steady state setup in CFX for a centrifugal pump rotating at 1450rpm, inlet BC of 0atm rel. total Pressure and 4.167kg/s Outlet BC with SST turbulence model. Ref pressure is 1 atm. Refined the grid to a Yplus of less than 5 for both the impeller and the volute. The problem arise when I run the simulation cause the RMS residuals be dropping and then suddenly increases to until it fails. The RMS P-Mass residual would drop and suddenly rise and be constant till it fails. On the Out File it would be saying a wall has been placed at the outlet if I run with only the impeller and at the inlet if I run with the impeller and the volute interfaced. Anybody who knows what might be causing the failure please help.
stephec1 is offline   Reply With Quote
Old   March 20, 2020, 01:39
Failures like this are common caused by something getting convected to the outlet boundary, and the outlet boundary cannot handle it. Usually it is a recirculation, but it could be other things. Have a look at the results file just before it crashes and pay close attention to the outlet.
If it is a recirculation causing problems at the outlet you have many options, the most reliable being to extend the outlet boundary further downstream to a location beyond the recirculation.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 20, 2020, 06:18
Calvin Stephen
What is most surprising is the wall forms at the inlet of the pump not at the outlet
Old   March 20, 2020, 06:22
Oh, in that case the recirculation is hitting the inlet boundary. This happens as well, and the fix is the same - move the inlet boundary further upstream to a location where there is no back flow.
Old   March 20, 2020, 08:49
Opaque will become famous soon enough
Just a thought, have you try running with a mass flow inlet condition instead.
It seems you are running incompressible fluid, correct? Then, pressure level does not mean much, just the change between inlet and outlet.
Hope the above helps,
Opaque is offline   Reply With Quote
Old   March 21, 2020, 00:51
Post Informational
M.Asif
Muhammad Asif is on a distinguished road
Hello Everyone,
I encounter the Informational problem while updating setup to go to solution.
Snapshoot attached,
Thanks in advance for Kind reply.
Muhammad Asif is offline   Reply With Quote
Old   March 21, 2020, 06:13
Do not post new questions on existing threads. For a new question, post a new thread.
But the error message in your case says exactly what the problems is - you cannot run the simulation until you set it up in CFX-Pre (the setup step).
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Simulation of flow through a Pump as turbine by Ansys CFX Aladinos05 CFX 6 June 13, 2017 22:34
Small cluster configuration for pump simulation at CFX Nevel Hardware 2 April 7, 2014 07:07
CFX Coronary Flow Simulation ld1305 CFX 13 February 7, 2012 04:17
Small cluster configuration for pump simulation at CFX Nevel CFX 3 February 3, 2010 23:37
