Domain
Old   April 7, 2006, 09:26
Default Domain
Mgtripple
Hi friends,
I have a nozzle which composed of two parts. I know that in the first part there is no combustion. Combustion occurs in the second part. I am trying to model with different domains. One reacting one not. But cfx doent let me do that
anyone has any idea ?
Thanks
Old   April 7, 2006, 10:19
Default Re: Domain
opaque
Dear Mgtripple,
Usually the ANSYS CFX solver does not like any change of physics in the flow passage (union of connected fluid domains).. You may try (risk of failing) to extract the commands file from the definition file, and using a text editor set the combustion model to None on the first domain..
If it works, you are on.. Otherwise, if you know is not going to burn, the solver should get the same results, right?.. Perhaps, you are using the EDM model and you need to set some limiters to prevent the combustion within the first domain..
Good luck, Opaque..
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 01:42
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 23:43
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
