December 11, 2019, 08:33 |
Accumulated timestep&coefficient loop
王莹
Rep Power: 9 |
Hello everyone,
I ran some cases by CFX and set some monitor points to get their variables. I set the software record these variables every timestep. However, when I checked the result, I found that the data was very strange. First, as the x axis set as "accumulated timestep", the value should be integer. In my case, some of the value is decimal, such as “4210 4210.5 4211 4211.5 ...”(Fig1). Second, when I exported the variables to ".csv" file, I found that for some timesteps, they have more than one value and there is a item"coefficient loop"(Fig2). I didn't set this value when I set the ".def" file. Hope that anyone can help me, it is so confusing. |
December 11, 2019, 08:47 |
Gert-Jan
Rep Power: 28 |
Your monitoring data contains the iterations (Coefficient loops) within a timestep as well. Default is that it only plots only the end value of the timestep.
This is because in your Output Control, you have selected "Monitor Coefficient Loop Convergence". If you turn this off, then you will go back to the default settings. |
December 11, 2019, 23:26 |
#3 | |
王莹
Rep Power: 9 |
Yes! That's exactly the reason,thank you very much!^_^
accumulated timestep, coefficient loop |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
[Gmsh] Extrude on gmsh | Pedro Felix | OpenFOAM Meshing & Mesh Conversion | 0 | October 30, 2019 13:33 |
Need help setting up chtMultiRegion | OskarT | OpenFOAM Pre-Processing | 1 | September 25, 2019 16:51 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 16:57 |
