Simulation two Phase flow without Interfaction
Old   August 14, 2019, 04:00
Default Simulation two Phase flow without Interfaction
Sasan Ghomi
sasanghomi is on a distinguished road
Dear friends,
I am trying to simulate a piece of solid which is cooled down by two fluids (air and water) separately. In fact, there is no interaction between water and air. My question is that how I can simulate such case without going through two-phase modeling. Honestly, I don't want to deal with volume fraction and the like in order to simulate the case because the above mentioned fluids have no interactions and they just touch the solid separately.
The problem is that when I use one fluid in Pre-CFX, I cannot define two materials for the domains and I have to define two fluids (two phase) in order to specify two separate materials for my case.
Do you have any idea? Modeling a two-phase flow is the only solution that I can go through?
Best Regards
sasanghomi is offline   Reply With Quote
Old   August 14, 2019, 06:32
Modelling it as a two phase flow is the only approach which is officially supported. But there is an unsupported feature where you set the expert parameter "allow unmatched domain physics = True" (or a name very similar to that, do a search to get the exact wording) and then you will be able to set different fluids in different domains but not use a multiphase model. But be aware it is unsupported, so be careful.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   August 14, 2019, 07:49
Sasan Ghomi
Thank you so much.
Do you have any suggestions for the simplest setup for running a two phase simulation in which there is no interactions between two fluids (Air & Water)?
There are different models for multi-phase flow simulations. Any idea with the least computational cost?
Old   August 14, 2019, 08:21
If you want to run this as a multiphase model then set both fluids as continuous fluids just like for a free surface simulation. The only difference being you don't define any interface model or surface tension. Make sure the momentum equation, turbulence equation and heat (if you have it) are set to homogeneous. Then you are only adding a volume fraction equation so the additional cost is small.
But the biggest problem with this approach is that the large density difference between air and water is like to make convergence harder than a normal single phase model. You won't know if this is problem for you until you run it and try it.
Old   August 14, 2019, 12:48
Sasan Ghomi
So helpful, thank you for sharing your ideas.
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 13:12
Direct numerical simulation of species transport equation with phase change Pmaroul Main CFD Forum 2 October 12, 2018 17:02
Bubble plume simulation, multi phase flow Artvandelay Main CFD Forum 5 August 23, 2018 04:52
Two phase flow problem. andyraq Fluent Multiphase 4 August 21, 2016 22:57
two-phase flow with a single phase simulation caunima Fluent Multiphase 0 October 28, 2013 03:42
