Help regarding high quality figures from CFX-post
Old   August 26, 2005, 15:26
Default Help regarding high quality figures from CFX-post
UY
I am using CFX 5.7.1 to simulate a stirred vessel. When I printed the figures in the format of jpg from CFX-post, I found that the quality is not good when I put it into word file. How to improve it? Help needed!
Thanks in advance!
Old   August 26, 2005, 16:10
Default Re: Help regarding high quality figures from CFX-p
Rui
When you choose the format jpeg, on the bottom of the Print window there is the box Image Quality. The default value is 80, you may increase it to 100.However, to obtain better quality images select the format Bitmap. But the files size will be much larger.
Hope this helps.Regards,
Rui
Old   August 27, 2005, 15:45
Jeff
In my experience, higher quality PNG formats give better results with smaller file sizes.
Jeff
Old   August 29, 2005, 04:05
Michael Bo Hansen
NEVER use JPEG compression for CFD plots. The Jpeg-algorithm is designed for real life photos and not for colorfull CFD plots. Use PNG with size 1820x1280 (for instance). - Michael
Old   August 29, 2005, 17:37
Fred
Create a PNG at 200% scaling, then reduce the image size in Word. Your monitor displays at ~70 to 100 DPI (Dots per Inch), whereas your printer is typically 300 to 600 DPI. The higher DPI makes pixelization more obvious.
With CFX 10.0, Post will also anti-alias the image (default "High Quality" output), which further smooths lines and contours.
Regards, Robin
How to generate good quality figures from cfx-post Ken CFX 9 April 4, 2016 05:41
Transient animation performance in CFX 5.5 POST Sjoerd Romkes CFX 8 February 5, 2013 15:53
turbFoam vs CFX - 2D case high Re ffucile OpenFOAM Running, Solving & CFD 17 October 21, 2009 05:01
CFX Post export problem jeff_F CFX 0 August 17, 2009 22:25
chart for transiente simulation - CFX Post rogbrito CFX 0 June 22, 2009 13:12
