Velocity not match over the interface area
Old   January 10, 2019, 04:10
Question Velocity not match over the interface area
Jolly is on a distinguished road
Learning the CFX software recently and has been stuck by a same issue for two days.
I separate the flow area into two domains, one is stator and another is rotator, also use interface(frozen rotor)to connect them.
But after calculation , I found the velocity was disconnected between the two area.
Can I get help from you? Thanks in advance
Jolly is offline   Reply With Quote
Old   January 10, 2019, 04:50
Gert-Jan
Gert-Jan will become famous soon enough
Did you read this FAQ: https://www.cfd-online.com/Wiki/Ansy...f_reference.3F
Gert-Jan is offline   Reply With Quote
Old   January 10, 2019, 21:20
Smile
Originally Posted by Gert-Jan View Post
Thanks! I'll go through it first
Old   January 10, 2019, 22:40
Smile
Thanks a lot , problem solved and I also learnt the reason behind that.
Old   January 13, 2019, 15:40
Gert-Jan
Jolly good.
interface discontinuity
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY everest20 FLUENT 1 July 13, 2015 09:35
mean velocity through area tobi1492 CFX 4 February 6, 2014 18:10
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
