creat a pattern in DesignModler
Old   June 9, 2005, 11:14
Default creat a pattern in DesignModler
Jan
I have a question in gerating geometry with DesignModler. The inlet of my geometry is consist of ten columns. What I did is:
first, draw a circle; second, extrude the circle to generate a column; Third, I tried to use 'creat a pattern' to generate ten columns.
The problem is that in the third step, I can't choose the column to be 'geometry' option.
Could someone please tell me how to creat a pattern? If the inlet is consist of ten circle faces(not columns), how to generate it?
Thanks!
Jan
Old   June 11, 2005, 09:37
Default Re: creat a pattern in DesignModler
test
If you need the pattern of 10 circles on the inlet face only use the option of Imprint faces in the extrude option instead of the standard add material options
Regards, test
Old   June 12, 2005, 00:38
Jan
Thanks, test
Waht I did was exactly as you said, however I always got error message when creat feature (creat ten from one).
could you please give suggests to this step?
Best regards!
Jan
Pattern on football ball RiKR0K Main CFD Forum 0 March 22, 2010 09:37
Flow pattern in a Nozzle sean Main CFD Forum 0 February 2, 2009 05:36
How to creat geometry like this? Dayanjing CFX 3 June 7, 2005 07:10
Egyption Pyramid with All HEXA Selina Tracy Main CFD Forum 17 March 30, 2001 05:15
The Effect of impeller type on flow pattern lee ji hyun Main CFD Forum 1 January 26, 2000 09:35
