How to improve the quality of mesh expansion factor |
huang jun
Rep Power: 0 ![]() |
I use ICEM to generate an unstructured mesh with a maximum expansion rate of 16. I want to reduce the mesh expansion rate to 10, but I don't know how to do it.
Rep Power: 144 ![]() ![]() ![]() ![]() |
Generating good quality meshes is a skill which requires practise. There is no simple steps to improve any mesh. ICEM has a wide range of options so the user can use the one suitable for their application. So try out all the available options and see what works in your case. Also read the ICEM documentation and tutorials.
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[ICEM] Unexplained changes of mesh quality and blocking approach | salumi | ANSYS Meshing & Geometry | 9 | November 23, 2016 05:14 |
[snappyHexMesh] Improving mesh quality + inlet too coarse | MartinBlx | OpenFOAM Meshing & Mesh Conversion | 5 | August 2, 2015 23:09 |
[ICEM] Improve Quality of Tetra Mesh | geod | ANSYS Meshing & Geometry | 8 | December 12, 2014 10:14 |
Mesh Expansion Factor value acceptable?? | Danial Q | CFX | 5 | June 13, 2012 08:30 |
