October 14, 2003, 19:42 |
Fields as Boundary conditions?
Is it somehow possible to use a field, such as [x,y,z,property] , for definition of a boundary condition in CFX 5.6?
Say, for example, I want to solve a conjugate heat transfer problem, where there are flows on both sides of a solid body. Because it is too big to solve in one case, I will setup "internal flow + solid" as one case, and "external flow" as another case. From the "external flow" case I would like to export heat transfer coefficients on the external solid wall and import it as a boundary condition to the "internal flow + solid" case. Many thanks for your ideas. M. |
October 15, 2003, 20:02 |
Re: Fields as Boundary conditions?
Hi Martin,
One possible method is to export the heat transfer coefficients on the linking surface to a text file in CFX-Post, and to then import the data into the other run as a Cloud of Points user function, and apply it as the wall boundary condition for the other run. Glenn |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 13:58 |
Boundary conditions for 2D Navie-Stockes simulation | L1011 | OpenFOAM | 5 | December 13, 2012 09:17 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 10:38 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
