Condensation
Old   December 10, 2002, 17:19
Default Condensation
Christian
Are there any one how have try to use or implement condensation of mointure in the air from one phase to another(water) in either CFX 4 or CFX 5 ?
If so how is this done ? Any examples ?
Thanks
regards
Christian
Old   December 11, 2002, 09:07
Default Re: Condensation
Holidays
It has been done in both codes (not by me!). For CFX-4 check this out with CFX support because I have no details.
In CFX-5 you can manage your mass transfer via source and sink terms(The only thing I have so far is for evaporation however) . This should be generalised in the next release and since real gaz, cavitation are appearing in CFX-5 applications it should be even better.
Old   December 11, 2002, 13:58
Christian
Hi
Simple question.
Would you be willing to share your implmentation of sources and sinks for evaporation ?
Thanks in advance
Regards
Christian
Old   December 12, 2002, 06:46
Holidays
Evaporation Water to "Air" for example:
Set up an expression for the evaporation rate revap in kg m^-3 s^-1 en fonction de la temperature de l'eau par exemple Water at RTP.T which becomes a sink for the air and a source for the water. For exemple write a function based upon the temperature exponential around 373K to create a step function switching from 0 to 1 around that temperature smootly.
Then you must also withdraw the latent energy from the water with a sink in the form of: 2.28 [J kg^-1]*revap. Something along these lines should work well with CFX-5.5.1 solver. Look on the web for more details about such thermodynamics.
UDF for condensation or boiling Yvonne Fluent UDF and Scheme Programming 12 June 24, 2019 17:57
combustion radiation and condensation in cfx siden CFX 1 February 3, 2011 18:39
condensation on horizontal tube??? Wikie FLUENT 0 July 30, 2010 05:53
Condensation Problem Sudhakar CFX 0 June 4, 2008 23:14
condensation of water vapour at room walls Felix FLUENT 0 September 14, 2007 12:03
