September 2, 2017, 21:48 |
How to change component layout in Workbench
Jimmy
Rep Power: 10 |
My analysis has many gropes, sometimes I have to duplicate another component. The problem is that duplicated component always was set at original one right. How can I set component the location where I want it.
September 3, 2017, 06:36 |
Rep Power: 144 |
Will workbench parameters help you?
September 4, 2017, 04:02 |
I have checked every parameters, view, tools, units.....
Jimmy
Rep Power: 10 |
September 4, 2017, 06:49 |
Maxim
Rep Power: 13 |
If I understand you correctly, you want to move your components (such as "Mesh" or "CFX") around in your Workbench layout?
Just drag and drop them! You have to do that in line "1" where it says "CFX" or "Mesh" or "TurboGrid", see attachment. |
September 4, 2017, 08:09 |
Rep Power: 144 |
For workbench parameters have a look at the workbench tutorials. They are available on the ANSYS Customer webpage.
September 4, 2017, 19:53 |
Jimmy
Rep Power: 10 |
Thank you for your answer, But my problem is I want to use the same method in next group simulation. If I did not use duplication, I have to set all parameters one by one again and again in next group. For example, I simulate a tube and different simulation group for different diameter.In CFX setting inlet, outlet, boundary, etc., are same, so what I need do is just duplicated CFX component. But when I duplicated CFX component, It will be put on the original component right. How can I move them?
September 4, 2017, 19:54 |
Jimmy
Rep Power: 10 |
September 5, 2017, 05:08 |
Maxim
Rep Power: 13 |
I described you how to move the components around: drag and drop the components by clicking and holding the "CFX" field. Isn't that what you are asking?
If you don't want to set your configuration in PRE every time for a similar setup, you can save your config as a *.ccl file and load that setup in PRE (load *.ccl). That is described in all the tutorials. |
September 5, 2017, 05:42 |
#9 |
urosgrivc
Rep Power: 12 |
There is a simple solution to your problem if I understand corectly.
The problem is you only have a CFX tree. Use another tree that includes your geometry. => if you drag and drop (Fluid Flow CFX)=>(figure below) the geometry and mesh will be atached to the same tree. Than you specify your pipe diameter as a parameter and that is it. When you will duplicate the tree, geometri and mesh properties will go with it and you can just change the parameter walue to what you like, than it is just the mater of updating and solving a new tree. And you ofcourse dont need to make a whole new project just because of this change, you can just drag your geometry into this new tree and delete the conection and old standalone geometry. i use it all the time, works perfectly . see figure; https://drive.google.com/open?id=0Bw...jFKWVdFMDJZNW8 Did this answer your question? another thing: I dont know why ANSYS people completly renovated and ruined RMS I will probaly open a topic on that one (it was working perfectly why did they do that ?) I was always using RMS so multiple trees could be solved while I am not at the computer but somehow from ansys 18 and on this is not working enymore any simple solution to thaat?!. :/ Last edited by urosgrivc; September 7, 2017 at 02:02. |
September 7, 2017, 04:04 |
#10 | |
Jimmy
Rep Power: 10 |
Yes, it works, thank you very much! Thank you for your help.
September 7, 2017, 04:06 |
#11 | |
Jimmy
Rep Power: 10 |
Oh, you are such brilliant! what I can say. Thank you very very much, I will follow you.
July 6, 2021, 04:09 |
#12 |
Rep Power: 6 |
Hello
Thanks for this post. The answers have helped me in my quest too. Best regards |
[ANSYS Meshing] How to change element type in Ansys Workbench | vpvmech | ANSYS Meshing & Geometry | 2 | April 6, 2018 11:46 |
Parametric Mesh with ICEM and Workbench fails to update | fabian.schicker | ANSYS | 0 | May 9, 2017 09:20 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 05:27 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
How to change turbulence model in InterFoam | Gildeh | OpenFOAM Running, Solving & CFD | 4 | March 28, 2012 13:04 |
