Meshing error on CFX 5.5.1
Old   September 24, 2002, 15:40
Default Meshing error on CFX 5.5.1
Bruno Sersante
I´m working on CFX 5.5.1 with two tunnels of 1.8Km each . After set the initial conditions, I´m trying to create a surface mesh but the pre-procesor stops with the following error:
" Dr Watson: An application error has ocurred and an application error log is being generated.
srfmsh_gtm.exe
exception: access violation(0xc0000005), adress:0x7800d376 "
CPU description: - Windows NT.
- Pentium 4, 1.5GHz.
- 512 RAM.
Any help will be highly appreciated. Regards
Old   September 24, 2002, 16:56
Default Re: Meshing error on CFX 5.5.1
Astrid
Looks like there is a conflict with other applications. Close all other applications, including the small programs running in the background, and restart CFX.
To avoid this kind of errors, we have only installed CFX on our computers. In the past for example, we observed that Paint Shop Pro can have a conflict with CFX 4.
Astrid
Old   September 24, 2002, 17:42
Default THX Astrid
Bruno Sersante
Thx Astrid,
The problem appears in each computer that I use (3 differents computers)and i don´t know what to do.
If you have others suggestions, I'll apreciate it
Old   September 24, 2002, 19:42
Default Re: THX Astrid
Astrid
- What might help: Create a new directory, change the name of your .db-file and restart CFX-build.
- If not: dial 911 (your local CFX-Helpdesk).
Astrid
Old   September 25, 2002, 10:35
Dave
Bruno, I've experienced similar problems. Does the problem persist if you close build and then open it again ? Do you have any subdomanins defined ? Have you had a mesh out of the same podel previously ? Sorry for all the questions, Dave
Old   October 3, 2002, 18:53
hannah liang
I met the same problem when I write the def. file. especially when I define the subdomain. I am not sure if this is caused by software or other reasons.
Hannah
Old   October 4, 2002, 03:09
Astrid
Is it sensitive to the surface mesher used?
Astrid
CFX meshing moon1234 CFX 0 January 24, 2010 07:43
2D simulation - ICEM meshing for CFX question Ben Makhal CFX 5 April 11, 2007 09:44
CFX Meshing Error! C Mc Guinness Main CFD Forum 0 April 3, 2005 14:20
About PI meshing in CFX 5.6 David CFX 2 June 26, 2003 15:17
cfx, meshing + examples mark Main CFD Forum 1 December 22, 2000 00:10
