spinning cone
Old   March 27, 2002, 21:14
Default spinning cone
pumpkin
Hi, I'm a beginner with CFX 5.4.1, I'm trying to calculate the water flow on the spinning headstand cone, any message is welcomed. Thank you very much!
Old   March 29, 2002, 03:18
Default Re: spinning cone
Neale
What is a spinning headstand cone?
Old   March 30, 2002, 03:11
pumpkin
sorry to trouble you, let me make more description, in cartesian coordinate system the line y=x (x> 0 and x< 250 mm) rotate 360 degree aroud the z axis and get the cone. with the cone rotating, water is added into the cone, and spill out from the edge.
Old   April 2, 2002, 21:37
Neale
Seems to me that this requires a free surface model instead of full multiphase. Can you upgrade to 5.5 which has this?
You could try using full multiphase, but the overhead is quite a bit more than free surface. Just do a transient simulation with a small enough timestep to resolve the water pouring into the cone.
Neale.
Old   April 2, 2002, 22:09
pumpkin
Thank you! Neale
Definition of swirl fraction for hollow cone injection in Fluent launchpad FLUENT 0 June 30, 2011 04:22
DPM: Cone and Solid Cone injection - what's the difference? JaC FLUENT 0 January 5, 2010 10:20
Hollow Cone Injection Problem JaC FLUENT 1 December 3, 2009 04:03
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 12:49
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
