Multiphase flow and MRF
Old   July 17, 2001, 03:29
Default Multiphase flow and MRF
Yenni Chiu
I am trying to extend the application example 5 in CFX4.4, a rushton impeller with moving frames of reference, to a multi-phase fluid flow of gas and liquid. Based on the command file from the example, I added another phase and commands for MULTIPHASE PARAMETERS as well as the following lines under ROTATING COORDINATES PARAMETERS, i.e.
:>ROTATING COORDINATES
PATCH NAME 'USER3D-ROTOR'
OMEGA
POSITION VECTOR ON ROTATING AXIS 0.0 0.0 0.0
ROTATING REFERENCE DENSITY the gas density
The field was initialised to half filled with liquid at the bottom and no inflow/outflow. The computation stopped after a few iterations with error saying floating overflow.
Can anyone point out the possible error I made or commands I missed out? Thanks heaps in advance.
Old   July 17, 2001, 06:44
Default Re: Multiphase flow and MRF
Herve
Have you tried running the application as it is in the manual? Have you used the geometry from the example, in which case you will have noticed that you need to mend the geo file for the inside block to go between 1 and 27 instead of 2 and 27?
Old   July 19, 2001, 05:04
Yenni Chiu
Thanks for the response. Yes, I ran the application example as it is in the manual and also corrected the geo file. I now add false timesteps to 1.0E-4, the calculation goes but results are very unsatisfactory. The command set up is very basic for a multi-phase model. Is it too simplified to cause the difficulties? Yen
Old   July 19, 2001, 12:06
Herve
Multiphase is generally difficult to set up, and one could question the way you have set your model up. It would be good if you could post your command and fotran files to see in more details what you have done.
unbounded reversed flow on outlets kwardle OpenFOAM 8 March 7, 2018 11:34
pump prevalence at low mass flow rates Caterina Main CFD Forum 0 January 8, 2011 17:05
Should an empty MRF zone really induce this much cross-flow? sylvester OpenFOAM 5 November 18, 2010 04:48
Periodic flow librasu FLUENT 1 August 18, 2008 13:24
Rotating objects in flow using MRF Kyle FLUENT 1 December 5, 2005 20:29
